Help DENON 2805 5.1 Bi Wired front
Discussion in 'AV Receivers & Amplifiers' started by Geoxis, Apr 10, 2005.
Tags:
  1. Geoxis
    Geoxis
    Apr 4, 2005
    312
    Surrey
    +15
    :hiya: Hello,
    I recently bought a DENON 2805, I am very happy with sound and features but I am trying to have it in 5.1 bi-wired front. speakers, I do not seem to work it out.
    Do I have to connect them in (Speakers A) and (Surround back or Zone2 speakers) or Speakers A + B this way it won't be a real biwired can you please advice please :confused:
    Thanks for helping me.
  2. cR4cKF0x 5TevE
    cR4cKF0x 5TevE
    Sep 7, 2004
    2,103
    St Merryn
    +322
    Sounds to me like your getting mixed up between bi-wiring and bi-amping.
    Bi-wiring: you run the speakers from two speaker outs (+ve and -ve) on the amp to the four speaker connections on the speaker using a four wire cable in a 2 to 4 configuration.
    B-amping, you use two separate sources (different speaker outs on the same unit or different amplifiers) to run the high and low level inputs on the speakers.
    Bi-wiring is therefore pretty simple (once you have the right cable) but I'm not sure how bi-amping will work with your Denon.
    Hope this clarifies.
  3. Geoxis
    Geoxis
    Apr 4, 2005
    312
    Surrey
    +15
    What I mean was Bi amping.
    And yes I was confused, what is the purpose of Bi wiring does make any improvement to the sound??
  4. Weiman
    Weiman
    Feb 25, 2001
    25
    Gothenburg, Sweden
  5. Geoxis
    Geoxis
    Apr 4, 2005
    312
    Surrey
    +15
    Will try, will have to set it up al in manual, :D I wil spend long afternoons trying retrying and etc....
    Thanks for that anyway :thumbsup:
  6. Astaroth
    Astaroth
    Jun 22, 2004
    2,283
    63
    London
    +117
    The Denon manual does not give details on how to bi-amp as whilst it is possible Denon do not officially support it.
    If you do a search on bi-amping/ bi-wiring you will find many debates on if biwiring is worth it and if bi-amping using a single amp is even worth it.
    Best thing to do is to try it for yourself and if you can hear an improvement then great, if not then you have spent only a small amount on some extra speaker cable
