Help Denon 2200 not playing SACD
Discussion in 'Blu-ray & DVD Players & Recorders' started by grahammackie, Jan 9, 2004.
  1. grahammackie
    grahammackie
    Got my first SACD today hooray. Denon 2200 is connected to Yamaha DSP640 through 6 channel analogue and optical.
    Default setting for SACD audio is multi but I only get a low bass note through the sub. Only when I select CD do I get any sound through all speakers. SACD is Peter Gabriel and is a hybrid. What am I doing wrong ?
    DVDA, normal DVD's etc all work great...
  2. Gizmo 76
    Gizmo 76
    Aug 17, 2003
    2,233
    116
    The Apps are Calling :-S
    +522
    Just had a quick look at the yamaha manual, are your pressing the 5 channel input button?! As SACD will not work though your optical and it's easy to think the amp would auto switch to what you want :(
    Might be worth a look, you could also confirm your test tones on the denon 2200 side of things are working if this not the problem.
    Giz
  3. CARLOS
    CARLOS
    Feb 11, 2001
    5,999
    WEST MIDLANDS
    +1,227
    Obvious question but you have deffinately switched the amp to its six channel input ?
    Edit: Beaten to it :)
  4. grahammackie
    grahammackie
    Thanks guys - doh !! Have selected six channel input and I now get sound when Denon set to multi !! Unfortunately sound is only coming from the front mains - nothing from the centres or the rears. All other inputs from the 2200 work fine, test signal also OK.
    Should I be getting a true surround sound experience ??
  5. Gizmo 76
    Gizmo 76
    Aug 17, 2003
    2,233
    116
    +522
    hmmm. . . . . . . .
    If it's a hybrid disc, the default layer might be stereo, have you tried pressing your SACD setup button on the front of your player to switch between 'Stereo','Multi', and 'CD' modes??
    If not seem's strange due to the fact that your denon's test tone are working on all speakers, but hopefully this is the answer.
    Giz.:hiya:
  6. CARLOS
    CARLOS
    Feb 11, 2001
    5,999
    WEST MIDLANDS
    +1,227
    Its also possible that its only a two channel SACD disc and doesn`t have multi channel surround.
    Does it mention on the back of the disc case if its multi channel ?
  7. CARLOS
    CARLOS
    Feb 11, 2001
    5,999
    WEST MIDLANDS
    +1,227
    P.S If you like Roxy Music i can recommend this multi channel SACD disc :)
