Help Damaged my B&W!!
Discussion in 'Home Cinema Speakers' started by Dom H, Jul 20, 2003.
  1. Dom H
    Dom H
    Dropped when moving house, the front black plastic fascia on my 602 S2 is ruined, someone please tell me you can buy replacements? :(
  2. MuFu
    MuFu
    Jul 24, 2002
    1,191
    41
    NW2, London
    +4
    Fill out a B&W techincal support form on their site. They are normally pretty prompt in getting back to you and should be able to provide a replacement.
    MuFu.
  3. Dom H
    Dom H
    The site seems to imply that they only do replacemnts speakers and nothing else, ill try them thanks
  4. jhjerpe
    jhjerpe
    Mar 1, 2003
    696
    2
    28
    North London
    +63
    They do spares for the 600 series, I managed to get my driver replaced after an XBOX rage / flying controller moment..... for a reasonable cost. Any approved B&W dealer should be able to help.
  5. Dom H
    Dom H
    lol, but will they be able to replace the plastic fascia? Its grazed to hell. The actual drive units are fine (I think)
  6. MuFu
    MuFu
    Jul 24, 2002
    1,191
    41
    NW2, London
    +4
    Yes, they call it a "baffle assembly".
    MuFu.
  7. Dom H
    Dom H
    bugger, they can only supply the bottom baffle :(
    Does anyone know if plastic chips can be repaired, im sure car bumpers can be? Or if anyone knows of any light wood 602 s2's going let me know.
