Help Creating DVD??!?!
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by WBC, Sep 17, 2003.
  1. WBC
    WBC
    Guys,
    I am currently using Ulead VideoStudio7 to create a wedding video. The software is great, and from an editing perspective I know what I am doing.......However, I'm getting to the stage of finishing the project, just adding music etc and was wondering what would be the Best next step?????
    Should I author straight to DVD or should I save the project in its orginal format of AVI???
    I will want to create a DVD later on, that will include this video footage along with some others, so I'm sort of guessing I would want to save it as an AVI, is that right???? It's the one part of the process I'm confused about.
    The original footage in DV so I naturally want my end result to be as good as possible.
    Please Help!!!
    Stace :D
