HELP! Corrupted OS on my PC and no other PC for installation medi
TheReloaded
Hello,
I really need help. I enabled legacy support on my BIOS so that I can run Linux Mint on my secondary drive but then when I tried to run Windows again, it won’t boot. (Yes I did disable legacy support again.)
I have no other PCs to install an installation medium to my USB. Any ideas on what I can do?
Thanks! Looking forward to the replies!
EndlessWaves
Ask a friend or family member to do it? It's not technically complicated and doesn't require any personal information. It's just a case of plugging in a USB stick, downloading a program and then running it.
John7
Check the boot drive setting in the BIOS and make sure the PC is set to boot from the appropriate disk. Disable boot access to all other drives (temporarily).
TheReloaded
When I do sudo apt install woeusb, I get this error:
The following packages have unmet dependencies.
woeusb : Depends: libwxgtk3.0-0v5 (>= 3.0.4+dfsg) but it is not installable
E: Unable to correct problems, you have held broken packages.
I did everything else before that correctly
TheReloaded
Problem solved, used a different Linux Distro (Lubuntu) to install WoeUSB. Had to do a clean install of windows though :(
EDIT: Linux Distro not Linux OS
AVForums Movies Podcast: We review Dune and ask which is the best decade for horror movies?
