The obvious fix would be options and change the settings on invert controller but it sounds like you have already tried that.
I'm quite sure I know what you did.Anyone got any ideas???
Go back to the FNG mission in the campaign. Once you finish shooting the first row of boards, it should have something saying "Reverse controls looking up and down?"
Select no I believe.
If that doesn't work, select yes.
No problem, my younger brother had played that prank on me before.. It took me a whole game to figure it outThank you so so much. You were right all sorted now. Thank you again![]()
No problem, my younger brother had played that prank on me before.. It took me a whole game to figure it out![]()
Thanks god knows how it went werid in the first place. But thanks for sorting it out for me![]()
^_^hi im playing COD4 and the controllers are going weird - the right stick is working in reverse - ie to look up we always pushed upwards but now its looking downwards - very frustrating have tried the options and it wont work - anyone know what i can do??/
If you go to Options, you can easily switch between Look Inversion being Enabled or Disabled.
I think he said he tried that earlier and it didn't work.Just pointing out how easy it is to go
^_^
^_^
