I am trying to connect my xbox to my pc to stream music etc. Operating system is windows 7 64 bit. My xbox is connected over wifi to my router which is huawei echolife hg521 my pc is also connected wireless to this router however neither my xbox or pc can see each other the xbox says pc not listed and my xbox does not show in the network map. I am joined to an home network, i also tried setting up WMC Extender on the pc although it says no extenders in your network, i procede typing in the 8 digit code but when searching i simply get the message 'unable to find extender setup was unable to find your extender on the network. This issue might be caused by a configuration problem with your network, or your extender might not be connected to the same network'
Both my pc and xbox are both able to connect to the internet but they just seem unable to connect to each other
Things i have tried after surfing the net for answers
Checked all services are enabled including media extender service , PnP-X IP Bus Enumerator, Homegroup provider, telephony, dhcp client, RCP, Network connections etc all are enabled
But the only one that appears to fail is ICS the service wont start when i click start i get the following message ' Windows could not start the internet connection sharing (ICS) service on Local Computer Error 1079 The account specified for this service is different from the account specified for other services running the same process' Would i be right in thinking this could be the main issue here?
Enabled upnp in the router setting
changed ip from dynamic to static - currently set back to dynamic
Turned off all the firewalls including the one in the router
used ethernet cable between the xbox and router - still the same ( i cant connect all the connections using cables as the router only as 1 ethernet port
checked device manager for any yellow flags - no yellow flags everything appears ok
I am really a novice when it comes to this sort of thing so please any suggestions would be great thanks
