Quantcast
HELP Connecting two amps
Mr Neato
Ive got a NAD C370 and a denon 3803 and thought I had the ideal music/AV solution, all i needed to do was wire it in and fire it up. Well :confused: I read the advice on these forums and connected a interconnect between the'aux' output on the NAD and the front LR preouts on the denon, as i intend for the NAD to drive those two speakers but :censored: all happens. Am i missing something basic :confused:
Any help !!!!
davehk
Any help !!!!
It is generally better to connect an output to an input, rather than to another output :oops:
But let's assume you mean that you connected the LR pre-out from the denon to the AUX INPUTS on the NAD. Make sure that you don't have the tape monitor button pressed in. Select AUX input and it should work - don't forget to select the correct speaker ouputs with the front panel buttons.
you'll need to set the NAD's volume control to a suitable position and then calibrate the levels on the denon. Always set the NAD volume control to the same place in the future.
A better way, if you don't want to use the pre-amp section of the NAD for anything else, is to connect the denon outputs to the MAIN IN on the NAD (remove the links first!) - then you bypass all the controls (except the speaker selectors) on the NAD and just use those on the denon.
MarkE19
Which amp are the front L/R speakers connected to?
Which amp are the CD etc connected to?
Connect the speakers to the NAD. Connect all HiFi sources to the NAD. Connect the front L/R pre-outs from the 3802 to any input on the NAD.
Mark.
Mr Neato
Thanks for the two bits of help guys.
Davehk I did mean input. Nothing like early morning AV problems to test your grammer.
Waiting for the weekend to try your suggestions and hopefully some happy days.
