Help connecting PC to PWD7
Discussion in 'Plasma TVs Forum' started by *ChrisB*, Mar 13, 2006.
  1. *ChrisB*
    *ChrisB*
    Apr 22, 2005
    310
    Berkshire
    +11
    I've trawled via searches but am still not sure as to the best way of connecting my plasma to my pc so I'm hoping you guys might be able to help :)
    My PC has a Geforce graphics card with VGA, DVI & S-video outputs and I'm hoping someone could advise me on whether I would be best to connect it direct to my Panasonic PWD7 using VGA to VGA, DVI to VGA (if that's possible) or what would the picture be like if I connect it S-video to S-video via my Yamaha dsp750 amp ??
    Thanks for reading (& I hope that all makes sense :) )
    Chris
  2. hermanmunster
    hermanmunster
    Dec 23, 2004
    499
    Somewhere sunny and warm...I wish
    +24
    Use VGA on the PC to VGA on the on the screen. If you use DVI output via a dongle you are only sending the analogue VGA signal anyway so little point.
    As the DVI card on the PWD7 doesn't support 720p @ 50Hz or HDCP there is little point in purchasing one for a DVI-D to DVI-D connection.
    Avoid using S Video from your PC it sucks big time
  3. *ChrisB*
    *ChrisB*
    Apr 22, 2005
    310
    Berkshire
    +11
    Thanks for that :)
    As I only have the one VGA output on the graphics card should I use a splitter to switch from my normal pc monitor to the plasma ?? or what would you recommend ?
  4. hermanmunster
    hermanmunster
    Dec 23, 2004
    499
    +24
    If your graphics card has 2 outputs , use the DVI output with the dongle to convert to VGA for your PC monitor. It will work fine. Just need to set up a dual or cloned display within windows
  5. *ChrisB*
    *ChrisB*
    Apr 22, 2005
    310
    Berkshire
    +11
    Ok that sounds like just the answer :thumbsup:
    but just one more thing ....... and sorry for being a bit dim but what's a dongle ?? :blush:
  6. *ChrisB*
    *ChrisB*
    Apr 22, 2005
    310
    Berkshire
    +11
    Ahhh that'll be one of these then
    [​IMG]
    Thanks for your help herman :smashin:
  7. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    Hi Chris, just got in, I presume this was what the attempted PM was about? There is little to choose between VGA and DVI on the Panny SD screens, go for VGA cos it will cost you just a VGA cable, try 1280/[email protected] for starters, have a fiddle around from there. That will give you a workable desktop, correct aspect ratio at pretty fair sharpness. Steer clear of s-video, it will look like poop. It's fine for sky+ or any other half decent video source, useless for PC.
  8. *ChrisB*
    *ChrisB*
    Apr 22, 2005
    310
    Berkshire
    +11
    Great stuff :thumbsup:
    Thankyou too MAW (& yes it was :) )
  9. hornydragon
    hornydragon
    Dec 19, 2001
    28,345
    +1,218
    it is HDCP and will work on loads of resolutions just 50Hz is a pain i still reconmend VGA at 1280x720 for film media
  10. *ChrisB*
    *ChrisB*
    Apr 22, 2005
    310
    Berkshire
    +11
    Well thanks again guys, cable & dongle arrived, hooked 'em up and the picture's superb :thumbsup:
    (the SereneScreen Aquarium screensaver looks amazing :cool: )
    Just waiting for my audio cable along with a bluetooth keyboard and I'll be fully operational :smashin:
    Chris :)
  11. Walter Sobchak
    Walter Sobchak
    Mar 29, 2005
    1,034
    +37
    What bluetooth keyboard have you bought? Im wondering which one to buy.
  12. *ChrisB*
    *ChrisB*
    Apr 22, 2005
    310
    Berkshire
    +11
    I went for the Belkin package (keyboard, mouse & dongle)
    I'll report back my thoughts when it arrives :)
  13. *ChrisB*
    *ChrisB*
    Apr 22, 2005
    310
    Berkshire
    +11
    The Belkin bluetooth keyboard & mouse work beautifully (a bit strange setting it up as it didn't seem to finish the install fully as I had to cancel to get it to finish ??? but after adding each item ie keyboard & mouse to the bluetooth profile they both work really well).
    Because I use the mouse from an armchair I need to purchase a hard mouse mat to work best with the optical mouse but overall I'm really impressed (& not bad at just £35 delivered for the whole package :thumbsup: )
    Chris
