A
acabral
I want to connect my PC to my stereo system ensuring the highest possible quality ( I have quite a good stereo, but its the first time I try to connect to my PC).
1 - As I load my CDs into my computer (using Itunes for example) does it make any difference the quality of the CD drive in my PC regarding final music quality ?
2 - Is there any way to ensure that the CDs are loaded into the PC with no loss of digital information (which would come from encriptation for example) ?
2 - What is the best way to connect the PC to a pre-amp to ensure best sound quality? Should I connect the pre-amp directly to de PC? If yes, what cable? If not, should I use an external digital to analog converter (if this exists) ?
I am willing to spend some money, but I need to know if it would make a difference.
Sorry for the basic questions and thanks for any help
ac
ac
