Help Connecting my new cable pwd5!!
Discussion in 'Cables & Switches' started by Zippster, Feb 12, 2003.
  1. Zippster
    Zippster
    Dec 31, 2002
    200
    +5
    Hi guys
    ive just received my new scart to rgb component cable and was wondering how i connect it to the bnc terminal board on my new plasma
    i assume that the R,G,B connects to the RGB connections on the terminal board but what about the 4th???
    I (again) assume that it gets its sync from the composite input on the terminal board but i was confused when i saw the VD and HD connections on the board aswell?
    Where do i plug the other cable?? the composite in? or VD, HD
    What do i set the sync in the setup menu to ??
    Any help much appriciated
    Andy......
  2. codlord
    codlord
    May 17, 2002
    283
    Portsmouth, UK
    As you thought, you need to connect the 4th cable to the composite output and I think the menu option is "Sync on video".
  3. Zippster
    Zippster
    Dec 31, 2002
    200
    +5
    Thanx very much !
    Ta
    Andy...
    {looking forward to getting home 2nite}
  4. hearnj
    hearnj
    VD and HD are only used in the US were they have high def TV. You only need the 3 in the UK.
    You can get RCA to BNC adapters ..
    Jay
