HELP! Connect PW6 and xbox via vga
Discussion in 'Plasma TVs Forum' started by tim k, Feb 16, 2005.
  1. tim k
    tim k
    Ok heres my problem only 1 vga board on pw6, and i have an xbox to connect via component/vga and my freeview which goes scart into js tech box. Basically i need 1 more vga input board, is there any other way round it, like a vga switcher? I dont mind doing it manually if its going to save some of the hard earned. But what i dont want to do is disconnect the vga lead into the plasma as i have all the cables running neatly into conduit :)
  2. gizlaroc
    gizlaroc
    Jul 26, 2001
    9,579
    Norwich
    +1,013
    Do you have the JS box already?
    If not then get teh component version, this will make life alot easier.
    freeview-js-rca2vga
    Xbox-HDpack-rca2vga
    Both into a vga switcher, job done!
    If not you can do the same thing but you will have to go into the PW6 settings and change the VGA inout from RGB to YUV evertime you swap between tv and xbox.
    Is your Xbox modded?
    they is a hack to give it VGA out instead of component.
  3. tim k
    tim k
  4. gizlaroc
    gizlaroc
    Jul 26, 2001
    9,579
    Norwich
    +1,013
    yes mate that will be fine.
  5. lscolman
    lscolman
    Jul 31, 2003
    7,189
    Tyne & Wear
    +161
    Hi Tim,
    If you are serious about a good solution, then a manual switch box will not offer the bandwidth to maintain the signal quality from the devices. I use a Kramer VP200xl, as this allows bandwiths over 400MHz. They cost a bit, but as you have already invested in a plasma, it seems like a waste not to use good quality cabling.
    Check with Joe on www.tmfsolutions.co.uk, as he recommended it to me, and should be able to get you one.
    It won't be a tenner, but it will maintain the best signal quality possible.
    Cheers, Lee
  6. gizlaroc
    gizlaroc
    Jul 26, 2001
    9,579
    Norwich
    +1,013
    I reckon for anything up to 1080p that will be fine mate, 1080p is only 52hz, and all those switches will handle at least [email protected] which is over twice the bandwidth.
  7. tim k
    tim k
    Thanks for all the info, i dont want to scrimp after spending so much on my kit, but i do want a cheap solution to a vga switch, how comparable will the quality be??
  8. gizlaroc
    gizlaroc
    Jul 26, 2001
    9,579
    Norwich
    +1,013
    I don't think you will loose any quality at all on the resolutions you will be using.
  9. tim k
    tim k
    I think ill order it, i spose if i can tell any quality drop i can always up the budget. thanks for ya help :)
