Help..component Cable Not Working!
Discussion in 'Playstation Forums' started by sthetix, Nov 5, 2005.
  1. sthetix
    sthetix
    HI, I just bought an official PS2 Component cable from a local store. First, I setup the BIOS to component (first using RGB cable), then I switch to component cable, then plug the lead to the TV according to its colors...then i just heard the sound..Blank screen. HELP what must I do?
    My TV is set to Auto my PS2 is SCPH30002R (australian type) with Messiah Chip inside..any help from the pro???
    thanks a lot!!
  2. steve-o
    steve-o
    Jun 14, 2005
    408
    +5
    You made sure you got the R/G/B in the right sockets? Usually it wont work at all if you have some of them in the wrong one!
    Double check everything ;)
  3. sthetix
    sthetix
    Well, i've put the R/G/B cables to the right place. It's strange if i use my DVD player then i get the best pictures..but If i use PS2 ..then I get blank..the suspect:cable!..i think..
  4. Smiffy 2
    Smiffy 2
    Nov 20, 2004
    1,921
    2
    Bexhill on Sea
    +302
    I bought an "own brand" PS2 component cable from "Game" today for £9.99 and plugged the console into my Sammy for the first time (with fingers crossed.)
    Picture perfect.
    I was relieved
    :rolleyes: :rolleyes: :rolleyes: :rolleyes: :rolleyes: :rolleyes:
