HELP! Complete Newcomer In Need!
Discussion in 'Playstation Forums' started by dicanio, May 8, 2007.
  1. dicanio
    dicanio
    In need of a little help. :lease:
    I have just bought a panasonic viera 32" HD TV. I'v plugged my playstation 2 in and it looks pathetic. All the colours and sharpness have gone.
    My Question is, what is the best cable / way of connection to get the best from my TV?
    Also, where and how should I plug them in.
    I'm a new comer to all this, so please be gentle.
  2. Ol!ver
    Ol!ver
    Jun 28, 2005
    4,909
    Sheffield
    +110
    Completely unrelated, but I spotted your name. You an Owl, Hammer or Bhoy?
  3. DPT1976
    DPT1976
    Aug 24, 2005
    750
    43
    Essex
    +101
    A component cable is the best you can get for the PS2.
    http://www.amazon.co.uk/s/ref=nb_ss...-keywords=component+cable+ps2&Go.x=10&Go.y=12
    http://www.amazon.co.uk/s/ref=nb_ss...-keywords=component+cable+ps3&Go.x=18&Go.y=12
  4. wahman
    wahman
    Nov 19, 2006
    301
    28
    +41
    does a slimline ps2 come with a component cable?? i have a cable that plugs in the back of the ps2 and the one wire splits into 3 plugs. excuse the layman description but is that a component cable?!
    thanks
    iainw
  5. DPT1976
    DPT1976
    Aug 24, 2005
    750
    43
    Essex
    +101
    No that is a composite cable. It looks similar to component but the cable you have is only using one plug for the picture and two for the sound.
    Component uses three plugs for the picture.
