help - coaxial - rgb-s-video- phono????
Discussion in 'Cables & Switches' started by yoskiwoski, Apr 5, 2005.
  1. yoskiwoski
    yoskiwoski
    May 25, 2004
    356
    +19
    I have just got projector and have to move everything about, can I use a good phono to phono cable instead of shelling out again for a longer coaxial cable?
    Is an RGB cable ok for Component
    Is S-Video much worse than component?
    many thanx
  2. Reiner
    Reiner
    Jul 16, 2000
    3,316
    61
    Germany
    +13
    Yes, any video lead (75 Ohm impedance) will do.
    Generally not, it's only slightly worse (if noticable at all); but certainly not as big as the difference from S-Video to composite.
