Help choosing widescreen tv please
Discussion in 'General TV Discussions Forum' started by evolution400, Oct 13, 2004.
  1. evolution400
    evolution400
    Oct 10, 2004
    1,136
    38
    Cwmbran
    +17
    I am looking to get 28" 32" widescreen CRT that will accept component video.
    This will be used only for the gaming on the xbox.
    My budget is £650 maximum.
    what is the Cheapest 32" ? Cheapeast 28" ?
    whats a good quality 32" and 28"
    What about rear projection or a projector as another option ?
    thanks.
  2. evolution400
    evolution400
    Oct 10, 2004
    1,136
    38
    Cwmbran
    +17
    There must be somone on here willing to help a newbie !
  3. mrtbag
    mrtbag
    Dec 17, 2002
    3,509
    Anywhere I want
    +394
    Well, the question doesn't quite work out.
    You need to decide whether you are going for 'the cheapest' or 'Good Quality' or a mixture of both.
    If Cheapest then : Matsui 32WN20 - 32" Widescreen £349.99.
    If Good Quality then : PANASONIC TX32PS1+S - 32" Widescreen £584 (usually around 699)
    The above prices are from Dixons. But it may be worth just looking on www.pricerunner.co.uk to see what deals are about.
    Firstlty though, i'd make a few decisions so you are searching for something more specific.
  4. evolution400
    evolution400
    Oct 10, 2004
    1,136
    38
    Cwmbran
    +17
    Thanks for the response but the main features the TV must have is progressive scan and have component inputs does the panasonic have these features ?
    As I want to take advantage of the xbox HDTV feature.
    thanks.
  5. mrtbag
    mrtbag
    Dec 17, 2002
    3,509
    Anywhere I want
    +394
    Component inputs are very rairly found on European CRT sets. These are more commonly found on Plasma/LCD/Projectors. If your Budget is £650 max, Component inputs are not going to feature. Cheapest progressive scan I could find at 32" was Toshiba 32ZD26 £640.
  6. evolution400
    evolution400
    Oct 10, 2004
    1,136
    38
    Cwmbran
    +17
    Sorry if this is a silly question but can you get a component to scart lead ?
    So as this tv accepts progressive scan I can run 480p res from my xbox ?
    If not what do you suggest projection TV or projector ?
    Whole new topic then man :)
    thanks
  7. evolution400
    evolution400
    Oct 10, 2004
    1,136
    38
    Cwmbran
    +17
  8. GaryB
    GaryB
    Nov 12, 2002
    5,381
    St Albans
    +1,292
    Component inputs are increasingly common on CRT sets now. The JVC D40 IDTV and P37 have them.
    SCART signals and component signals are very different and you can't just get a cable to connect SCART to component - you would need a convertor.
  9. lynx
    lynx
    Jan 20, 2002
    4,634
    It always rains.
    +302
  10. evolution400
    evolution400
    Oct 10, 2004
    1,136
    38
    Cwmbran
    +17
    Thanks a lot for your help guys.
    http://www.be-direct.co.uk/productDetails.asp?referer=kelkoo&id=13735
    That seems to be a good price for the P37 but does the P37 have Progressive scan ? I cant see it on the featues listing but it does have component.
    So if I were to purchase this TV then if I were to try to display 480P res I take it that it would not display.........sorry I am a newbie :)
  11. Contact
    Contact
    Oct 17, 2004
    64
    Yes, but at the moment that's all dependant on the source of the image, so you need a Progressive Scan DVD Player. The JVC range with DIST all support HDTV as well as Progressive Scan.
  12. evolution400
    evolution400
    Oct 10, 2004
    1,136
    38
    Cwmbran
    +17
    This will be used for my xbox only.
    The xbox outputs HDTV 480p and 720p and 1080i with component out whihc is why I needed a TV like this it also plays DVDs in HD using xbox media center.
    If anyone has one of these TVs I would appreciate some coments before I buy it.
    Thanks again.
