Help choosing receiver!
Discussion in 'AV Receivers & Amplifiers' started by Rob coco, Feb 17, 2014.
  1. Rob coco
    Rob coco
    Feb 17, 2014
    3
    I need a new receiver/amplifier to do the following:
    1) power 2 sets of speakers independently (indoor and outdoor, that I can switch on/off independently)
    2) speakers are small Polk bookshelf type 80w or so
    3) have internal BT capability
    That's it, no home theatre.
    Can someone recommend a sensible choice that doesn't cost a fortune?
  2. PSM1
    PSM1
    Dec 20, 2008
    26,283
    +5,439
    What is your budget?
    Do you mean Bluetooth with the BT reference?
    What sources do you want to play in each location?
  3. Rob coco
    Rob coco
    Feb 17, 2014
    3
    Yes Bluetooth, and the sources are radio and iPad.
  4. Rob coco
    Rob coco
    Feb 17, 2014
    3
    Bud I was hoping to keep under 5
  5. PSM1
    PSM1
    Dec 20, 2008
    26,283
    +5,439
    What are you connecting via Bluetooth? Could you use Wifi or something like Airplay? Is there anyway you could hardwire something to the receiver?
    Not many AV receivers have Bluetooth built in and I know of no stereo amps that do. You may be better getting a third party streaming system connected to the amp. Also if you buy an AVR the sound quality will not be as good as a stereo amp for the same price and you will be buying a multichannel amp but not use it for its intended purpose. Teac used to do a multi zone stereo amp (980 I think it was called) but does not have Bluetooth although would give you 2 zones of stereo sound.
    The other option would be something like a sonos in each location. This would give easier control of the 2 zones.
