Question Help choosing new (used) projector upgrade
414
Hi All,
First time posting here though I have done lots of research in the past in this forum.
I've had projectors for around 10 years. Always budget Epson models - I currently have an Epson EB X39.
I need to use the lens zoomed to its maximum and then the quick corner keystone to bring the image inline with my projection area.
I'm looking for a used projector upgrade - something with a higher resolution (thinking WUXGA?) - or at least something that's a setup from my EB X39.
I mount the projector on a high shelf on a back wall 480cm away from the projection wall. The projection area is around 320cm diagonal.
I've seen a few good deals on an EB-4950WU, though with a much lower contrast ratio - is this moving backward/sideways rather than stepping up?
This will be my everyday projector for quite a while and my next step up will be a 4k projector in a couple of years.
Any advice for me? ... or mega bargains out there?!
Thanks in advance.
pragmatic
What sort of budget you looking at?
What are the features/performance you are looking for?
You can use projector central to check practical throw/zoom if location is limited.
There are some good budget ones that do pretty well, good value generally lies with LCD and DLP, if you have ambient light a brighter projector can help here to.
Otherwise there are plenty of cheap older PJs about, depending on your needs, the classifieds here can be a good source if bought from a known trusted member/seller.
