Help choosing dvd player/ snazio
elliothand
Established Member
Hi all,
I'm tempted to buy a dvd player but need some advice. I need one that can plug into a dvi d port, as don't have component in, and want video upscaling. My tv is not hdcp compliant but not sure if that affects me as I will be plugging in a standard dvd player not high def or blueray. Is that right?
I am tempted by the Snazio Net DVD Cinema HD but not sure if I really need the network feature as I can use my xbox 360 for that. How does the product compare to other products with regards to picture quality etc of equivilent price? Are there any others you can recommend that I should look at?
Will the difference between that product/ dvd players around £250 provide noticably better picture etc then my xbox or would I be better of saving the money and waiting for high def/blue tooth?
Tribit StormBox Blast Bluetooth Speaker: Review Coming Soon
