Help Choosing between 2 32"
kevnufc
I wasn't sure if I should make a new thread or hijack someone else's but decided to make my own to be on the safe side :)
I've recently decided I would like to buy a 32" HDTV and I cannot decide which is best, it will mainly be used for Xbox 360, connected through AV cables, from reading past threads the two I am picking up to be most popular for my budget are;
Sony 32S3000
or
Samsung 32R87BDX
I would like to keep it under £450 prefferably but if needs must I may consider spending more. Any advice would be greatly appreciated.
ChrisGgr
They are very good both and similar.
kevnufc
Thanks for the reply :) I'm torn between them at the moment.
Theres only £5 of difference between them at digital-point.co.uk and the only thing that really stands out between the two is the bravia engine. Is that enough to warrant choosing the Sony over the Samsung? I've never seen the difference between a bravia and standard so not sure how much a difference it will make.
ChrisGgr
As the price difference is small get the S3000
Podcast: CES '22 TV Announcement Round-up, Plus, Most Anticipated Movies of 2022 and More...
