I'm looking for a decent bedroom TV without wanting to spend a fortune and quite like the look of the Samsungs. However I cannot decide whether to go for the SM2333HD (£214.99 at Dixons) which is a 1080P monitor with digital tv tuner and seems to get very good reviews or Samsung LE22S86BD (about £220 or £177 if graded) or Samsung LE22B450 (£212 at Dixons), both of which are TVs rather than monitors. There's also the Samsung T220HD at Richer Sounds.
I'm usually pretty good at working out which is best but I can't get anywhere with this. I think the LE22B450 is an older model than the L22S86BD but the differences in features and resolution etc are confusing.
I am also open to other suggestions but would prefer to stick with a decent brand (Samsung, LG, Panasonic, Sony etc)
I am only likely to use it as a TV if that helps.
