Help Choosing a replacement for my Onkyo 875
lilmil
Established Member
Hi Guys,
So I recently sold my Onkyo 875 for only 265 as I needed the cash and like to change my equipment around every so often!
My problem now is that I am looking for a replacement and no other receiver seems to be as good value or much better for not too much more!
Assuming a budget of maybe 300-500 what would people recommend. Is it possible to get a pre/power amp setup for the upper end of that which would beat the onkyo?
My front speakers are Dynaudio Contour 1 mkII, centre is a Dynaudio Audience c120+ and rears are wharfedale diamond 9.1s. The Contours are 4ohm and the rest 6ohm.
I would be grateful for any thoughts people have!
PSM1
There is no way you will get a pre/power amp for £500 even second hand so I would discount that option. Your speakers are reasonably low impedance so need a fairly beefy reciever to be able to handle them without risking either the speakers or reciever.
I would be looking at the Yamaha 106x or 206x or Denon 23xx or 33xx as equivalents to your old reciever. If you do not mind forgoing audio over HDMI then the Arcam 350 would be worth a look as well.
lilmil
Established Member
What would pre/power amp cost? Using a 275 Onkyo like my old one as the pre, how much would I need to spend on a power amp that was better quality than the onkyo. How do the yamaha and denons stack up compared to the onkyo? Any advantages or should I just be sticking to the onkyo and find another one!
PSM1
Yamaha/Denon have a different sound to Onkyo (warm compared to bright). This is siad to be better for music but can lack detail with films. If you liked your Onkyo sound then it may be better to stick to brighter sounding amps like Onkyo/Sony/Pioneer.
A multichannel power amp will cost at least £500 I would guess if not more (look at ones made by Arcam or audiolab on ebay as an example of secondhand value).
lilmil
Established Member
Thanks. I see this in the classifieds:
http://www.avforums.com/forums/ampl...egra-dta-9-4-7-channel-class-d-power-amp.html
Would this with an 875 give me a much better sound?
Isn't there any way to get it a bit better without spending over twice as much? I was expecting maybe a recommendation for a good stereo amp for the front two speakers?
Or how about using an Onkyo 875 and Arcam AVR300. That wouldnt be much more than 500. Would it be much better?
Samsung & LG UK TV Prices 2023; Amazon Fire TV Cube; Calibration Tools of the Trade + AV news
