HELP - Cheapest online seller of Saw?
southpaw
Where is the cheapest place to get SAW on Dvd?
Cheapest I've seen is £6.99 at Play or £7.99 for uncut version.
TheDot
This isnt exactly helping you, but may as well tell you in case. Music Zone have this for £3/4.
Charlton Fan
Sorry, haven't got time to look for you now, but CD-WOW had the cut version for £4.99 a couple of weeks back so might be worth checking there if that's any good for you?
Chris
southpaw
Checked CDwow but they're £11.99 after using the link.
Also there are no local MusicZones otherwise I'd try them, so the web is the only way HMV had it for £19.99!!!!! (oh and it was the cut version!)
jamiev
dave1de
As somebody said before its £6.99 from play.com
Trending threads
