help - cheap big screen needed
Discussion in 'Projectors, Screens & Video Processors' started by moggith, Jan 22, 2008.
  1. moggith
    moggith
    Oct 8, 2007
    84
    hi all - have just upgraded my pj from an old nec unit to a benq w100 and the throw is different - which means i need a bigger screen:oops:
    i was using a ebay special! roll down screen/black out blind - which i thought worked quite well,as the screen is mounted in front of my lounge window and worked as a blackout as well as a screen - but it is no longer big enough
    money is tight as i blew all my pennies on the new pj
    can anyone recommend a supplier or advise on what to buy -
    i need something that is 8' across, and will act as a black out for the window
    i have seen one on ebay but i want to do my new pj justice - are these blind/screens acually any good - or would a proper screen be better? and if so where can i find a cheap one -
    thanks in advance
    dean
