Help- cd plays fine, dvd is scrambled dv88+
Discussion in 'Blu-ray & DVD Players & Recorders' started by cbrehm, Oct 22, 2005.
Tags:
  1. cbrehm
    cbrehm
    Oct 14, 2005
    11
    Maryland
    Hello,
    I have just hooked up my dv88+ and the dvd is scrambled. I tried component, svideo and composite, all were scrambled. Anyone ever experienced this? Thank you.
  2. ginaandlee
    ginaandlee
    Do you mean the picture is scrambled? Do you have it set on PAL instead of NTSC or vice versa? Need a bit more info to help :)
  3. Crustyloafer
    Crustyloafer
    Sep 12, 2003
    9,578
    Edinburgh
    +1,269
    Try pressing and holding the stop button on the front of the player for about 5 seconds. This will reset all video setting to default.
  4. cbrehm
    cbrehm
    Oct 14, 2005
    11
    Maryland
    Thanks.
