Help cautious CRT owner
Discussion in 'Plasma TVs' started by vincentsdv, Jan 4, 2005.
  1. vincentsdv
    vincentsdv
    I've just received a Viera plasma and I have some concerns.
    I reduced brightness and contrast for running-in period.
    I use a DVI DVD player and Dreambox receiver with YUV output connected to the plasma through VGA port. So the sources and connections are the very best.
    I'm generaly satisfied with the PQ, but I'm coming from 36fs70 sony CRT and sometimes I'm disturbed by solarisations, green dots on black and poor shadow detail in dark scenes.
    Is there any chance to get rid of them after the running-in period? Can anyone confirm that plasma's PQ get improved in the long run?
  2. happyh
    happyh
    Aug 6, 2004
    309
    Northants Riviera
    I had mine professionally calibrated. PQ went from 90% to 99%.
    Don't know anyone in Romania though. :)
  3. blindlemon
    blindlemon
    Off topic I know, but how do you find the PQ from the Dreambox through the plasma compared to DVD?
    I'm thinking of getting one but have not seen it through a decent display and they are only available mail-order in the UK.
  4. c.hilding
    c.hilding
    After the run-in period you calibrate it correctly, then it looks better than a CRT!
  5. vincentsdv
    vincentsdv
    The PQ from Dreambox leans upon the broadcasting quality. However, the channels with high bitrates offer a picture similar with my dvd's (Yamakwa365). The SCART from Dreambox can output the component signal. Connected directly to plasma through vga port offers the best PQ. You even don't need JS RGB scart to RGBHV convertor box.
    Thank you for the answers.
