Help-Capture card again, Sorry
Discussion in 'Desktop & Laptop Computers Forum' started by minimivic, Jun 12, 2002.
  1. minimivic
    minimivic
    Mar 28, 2001
    230
    Shaftesbury, Dorset
    +16
    I've looked through lots of posts about TV capture cards and there are no definitive answers ( that I can find ).
    I want a card that is capable of recording SKY and preferably use it like a PVR. I am happy to get another dish installed and use a Wintv Nova card, but do they support Dscaler yet?
    The Sat download seems like a good option on the WinTV Nova any experiences?.
    Am I better to get a SKY box with an S-video out and use a different card?
    Falcon is a option but what about the sound issues, is it a problem or can the sound go into the sound card easily?
    How much is the Falcon?
    That will do for now, hope someone can help.:)
  2. Jeff
    Jeff
    Jul 13, 2000
    5,507
    Basingstoke
    +263
    Getting Sky+ would solve most of your problems. PC based PVR solutions simply don't cut it. With Sky + you can use DScaler for the recordings as well as live stuff and keep the sound external. Much more elegant as a solution.
  3. NickBull
    NickBull
    I email the Falcon distributors and got this reply :
    1. Falcon PCI Frame Grabber, including demo s/w, Windows Drivers, SDK, Manual unit price: £145.00
    2. Cost of carriage: £10.00
    Total cost: £155.00
    prices exclude VAT @ 17.5%. The delivery is ex-stock - next day.
    Call it £183 inc.
    It put me off a bit at the price, so I'm sticking with my Pinnacle Rave card (£35). I've sheilded it using a tinfoil sandwich (foil and card in an a5 envelope wrapped round the card), I also moved it to the furthest slot from the Radeon to avoid fan interference, I also got an RF filter/surge protector. I cleaned up a lot of the noise and now can use the card without much Noise Reduction, if any.
    I only use it with Svideo from my LD and sometimes a stand alone player for dodgy discs and the results are impressive.
    Not tried satelite other than through an RF video link, this is not ideal so I reserve judgement!
    Nick
  4. minimivic
    minimivic
    Mar 28, 2001
    230
    Shaftesbury, Dorset
    +16
    I seems to me like its not worth doing TV capture:(
    I thought it would be nice to decode Satellite, with the PC and send it to my HT300.
    It seems such a waste using a HTPC just for Movies when TV could be so much better.
    The PVR side would be a bonus but if its not easy its not worth it.
  5. NickBull
    NickBull
    #Why not try a Pinnacle or other chreap card that is supported by Dscaler, and give it a go? For the sake of £35 you'll know for sure.
    Make sure you do a search on the AVSFORUM in the U.S for the Adaptive noise filter, as these make a great deal of difference.
    I get pretty good results, but because I used a video sender and not a direct connection, it could be better. Still, ideal for a room full of people watching the footie!
    With Laserdisc and DVD you get a lot better results, I'd say that it's pretty stunning using my old Sony DVD player through the Svideo input. Laserdisc has a fault, and creats a lot of noise, but the filters in Dscaler do a respectable job on it.
    Give it a try, for £35 it's a great way to get TV etc onto your projector. VHS, however, looks pretty dire!
    Nick
  6. Couch Potato
    Couch Potato
    Is the Falcon still the Capture card of choice or has something else come along and got it beat.
    I want the best possible quality so I can feed sky/dvd/vcr and use dscaler for the resulting image to CRT
    Steve
  7. oreoboy13
    oreoboy13
    I cant remember where but i read an old thread on here last night that came up with a very good reason to get the cheaper £35 card as a stop gap until the new falcon card comes out.
