Help -can't seem to connect my home cinema speakers to my AV receiver?!
Discussion in 'AV Receivers & Amplifiers' started by dumbass, Dec 14, 2004.
  1. dumbass
    dumbass
    I have a Pioneer VSX-C501 AV receiver and am trying to connect some QED Genesis Silver Spiral speaker cable. Quite simply, the end of the speaker cable is far too big for the socket... Is there something I need to remove from the connection on the back of the AV receiver? I presumed all speaker cables worked with all AV receivers?!?
    Thanks in advance for any help! :)
  2. dumbass
    dumbass
    Or is it because there are plugs on the ends of the speaker cables? Do I need to strip them back to the wire?
  3. jasper_mccrea
    jasper_mccrea
    Dec 5, 2002
    882
    London
    +20
    If your speaker cables have plugs that won't fit into the spring-clip terminals (I'm assuming that's what you have) then you will need to strip them and just plug the bare wire, yes. Won't make it sound worse, plugs are purely for convenience. Say if you have to disconnect and reconnect a lot - I only went to plugs after having to disconnect and reconnect amps 4 times in a week. Never again!
  4. dumbass
    dumbass
    Nice one.
    Cheers mate. :smashin:
  5. Tejstar
    Tejstar
    Dec 4, 2002
    22,516
    London
    +1,005
    When you strip the wire, make sure you twist the strands of copper - this should prevent short circuiting - plus it'll be easier to thread through the holes!
