help can't get my battery off
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by peet, Mar 13, 2005.
  1. peet
    peet
    i need some help
    i have a panasonic pv-dv900 camcorder and i can't get my battery of the recorder.
    the slide does not seems to be working.
    any help?
    thnx
  2. Brian110507
    Brian110507
    Are you sliding and HOLDING the battery release button as instructed on page 11 of your manual ???
    Don't forget to lift the eyepiece up as well to provide clearance on removal.
  3. peet
    peet
    yes i did all those things but it does not work :eek:
