Help! Can't get Doly Digital / DTS
pauljames
I have a Playstation2 as a DVD player connected via Toslink to a Pioneer VSX-859RDS amp and then on to Eltax Jupiter speakers.
I cannot seem to get the amp to detect anything other than Pro-Logic when playing a DVD. The amp is set to auto-detect and I do get sound through it although only the Pro Logic lamp is illuminated on the amp.
The PS2 only has the option to enable/disable optical out and this is enabled (it should output DD/DTS).
I have tried several DVD's including Ice Age, The Matrix and Gladiator (with both Dolby Digital and DTS options tested) but to no avail.
What am I doing wrong?
Thanks,
Paul
PS I have posted this in both the Amplifiers / Receivers and DVD Players forums as I am not sure where the problem is.
DodgeTheViper
As well as setting your PS 2 for Optical out, and making sure it is set to DD as well. Have you set the Audio settings on the DVD menu ? Some of these you have to set yourself. Try it !
Kev
pauljames
I didn't realise I had to.
I will try that tonight. Thanks for the quick reply.
Podcast: Q Acoustics Q3030i, Humax Aura, Roku Streambar & WandaVision Reviews and more...
