help can't connect
jayls6
iv'e had my canon 400d for two weeks now ive taken some good shots with it but when i try to connect to my pc it does not see it can anybody help :lease:
V
vulkan75
Connect to usb after you have started the computer.Try different usb ports,if that dont work I recommend a card reader.
It should be picking it up as a removable storage device.
Maybe you need a usb driver for the camera.Itll be on the software disk that came with the camera if there id one.(windows xp and vista should pick it up though:confused: )
hernando
try Card reader for you CF Card.
if you still need help , tell us more about the problem ,, Windows version ? have you install the Drivers in the canon Disk ? what error you get ?
good luck
