HELP Canon wireless Ixus
Discussion in 'Photography Forums' started by n0chex, Dec 27, 2006.
  1. n0chex
    n0chex
    Oct 31, 2003
    7,697
    Here on AVF
    +418
    I have a little problem with wireless on my ixus wireless camera it connects but after 10 seconds or so it disconnects ,i have looked into the wireless Belkin router options but nothing stands out what is obvious any pointers to why it keeps disconnecting .
  2. onefivenine
    onefivenine
    Nov 5, 2003
    3,353
    Edinburgh
    +616
    There are a fwe things I would try to attempt to work out what the problem is.
    1) Log on to your router and enable logging and try connecting again.
    Then you should be able to browse the logs and see if any messages/errors point in the right direction.
    2) Another thing to look at is the Windows event logs. It might be that your Windows XP firewall or some other software is blocking the connection.
    You might need to enable the camera software in windows firewall or it might need you to open a port.
    3) Or you might have MAC address filtering switched on in your router in which case you need to add the camera's MAC address to the filter list in the router.
    Hope this helps. Let us know how you get on.
  3. n0chex
    n0chex
    Oct 31, 2003
    7,697
    Here on AVF
    +418
    Thanks mate it was my Firewall .
    Sorted Mods close
  4. onefivenine
    onefivenine
    Nov 5, 2003
    3,353
    Edinburgh
    +616
    Nice one, glad you worked it out!
