Help! Cannot get the SPDIF to carry full 5.1
Discussion in 'Desktop & Laptop Computers Forum' started by Mark Payne, Mar 26, 2005.
  1. Mark Payne
    Mark Payne
    Hi All
    Config is an Elonex Artisan PC running MS Media Centre Edition 2005.
    Well... I cannot fix it!
    All this is about the Realtek SPDIF output..the analogue outs work fine.
    Media Centre will not play anything through anything other than the Left and Right via the SPDIF.
    The little audio test available through Sound Effect Manager (in the control pannel) goes around and tests each speaker, but it fails on all but the Left and Right fronts.
    BUT if I start Cyberlink PowerDVD 6 and play a DVD using that then it all works! The amp recognises DTS or Dolby Digital and off we go.
    I have messed with all the settings I can see to no avail.
    Anyone fixed this?
    Mark
  2. markxtc123
    markxtc123
    Jan 27, 2005
    265
    +16
    See my answer in the Elonex thread
  3. mikeycrawford
    mikeycrawford
    Nov 27, 2002
    116
    Same here with an Audigy 2 soundcard going to a Pioneer Amp.
    My understanding from reading other threads here is that only a Nforce based motherboard can do on the fly encoding to 5.1, so unless you are sending a DD 5.1/DTS signal down the SP/DIF (like your DVD played throughPowerDVD), then the best you can hope for will be sound out of the L+R speakers.
    It stumped me for quite a while too .....
    Mike
  4. mrmoo
    mrmoo
    Jan 10, 2005
    517
    +19
    Get AC3filter set it to SPDIF to use all channels.
  5. Ar-Jar
    Ar-Jar
    Feb 3, 2005
    45
    Look for "Dolby Digital Live" technology on the motherboard. DDL encodes any sound up to 5.1 or 7.1 Dolby Digital so that you can decode it in your receiver and you only need one cable to the receiver. Many new mb:s, like my new Asus, have that technology now. For a htpc you don't need a separate sound card anymore.
    -A
  6. Pbryanw
    Pbryanw
    Nov 15, 2004
    1,524
    N.E. Lincs
    +101
