Danzolarenzo
- Joined
- Jun 20, 2012
- Messages
- 3
- Reaction score
- 0
- Points
- 1
Thanks for looking at my post
A buddy of mine is currently in China so I asked him to look out for cheap cameras capable of shooting a low budget movie that has the option to plug in an external microphone and he just came back to me with one. Can anybody tell me by the following specs if they think it will be any good. He just sent me the pictures so I will try and post the pictures on the post.
Camera Spec:
Full HD: 1920 × 1080P; 30fps, of H.264
16 million maximum static camera pixels (interpolated)
5 million effective pixel CMOS
3.5-inch LCD touch screen
120 times large zoom (12x optical, 10x digital)
Dual video capability, anti-shake function to support dual SD card
Lithium battery NP-120
Sensor 1/2.5 "the CMOS 5 million pixels sensor
Maximum output of 16 million pixels, the highest camera pixels (interpolated)
Storage Media Internal: built-in 128MB flash memory
External: SD card (up to the SDHC 16GB Class6)
Sensitivity Auto
Color effects natural / black / brown
Lens 12 optical zoom lens
Wide Angle: F1.85, f = 6.3mm Tele: F3.1, f = 75.6mm (equivalent to 35mm 38-459mm) 9G13E (with ND filter)
Focus range Normal / Manual Focus: 10cm ~ infinity (Wide), 90cm ~ Infinity (Tele)
Image Format: JPEG (EXIF2.2), DCF
Resolution: 2M, 5M, 10M, 16M (firmware interpolation)
Continuous: 5M, up to 12 photos / sec; 1M, up to 30 photos / sec.
Video Format: H.264 (AVI)
Resolution: WQVGA240fps, WVGA30fps/60fps 720P30fps/60fps, 1080P30fps
Dual video: 1080P30fps/720P30fps
Zoom 12x optical zoom, 10x digital zoom
Playback: static (8X)
TFT display 3.5 "TFT (960 x 240 pixels) (16:9)
The effective range of LED lights: 0.5m ~ 1m Mode: On / Off
Flash modes: Auto / Forced / Off
White Balance Auto / Sunny / Cloudy / Tungsten / Fluorescent
Exposure Compensation -2.0 EV to +2.0 EV in steps of
Self-timer off, 5, 10 seconds
PC interface MSDC: USB 2.0 (high speed)
TV out format NTSC / PAL / HDMI
Shutter static: the 1/2-1/2000 Video: 1/30-1/2000
Auto Power Off Off, 5 minutes, 10 minutes
Power lithium-ion battery NP-120 / DC input (USB
Thanks for looking and any info will be much appreciated
Camera Spec:
Sensitivity Auto
