Help - Can I Use Palm Tungsten T as a remote control ?
Discussion in 'Home Cinema Control & Remote Controls' started by newstuart, Jan 26, 2005.
  1. newstuart
    newstuart
    Apr 22, 2004
    1,680
    Northumberland
    +60
    Hi ALL
    Ive just aquired a Palm Tungsten T PDA and would like to know if I can use this as a remote to replace my pronto ? if so what software would i need ?
  2. newstuart
    newstuart
    Apr 22, 2004
    1,680
    Northumberland
    +60
  3. smooth-op
    smooth-op
    Mar 26, 2003
    71
    Ashford, Kent
    iv seen some software on the palm web site
    also try this one
    http://www.pacificneotek.com/omnisw.htm
    if you find any dececnt free software for remote control as im also looking
    as i dont wanna pay hehe
    cheers
  4. Timh
    Timh
    Sep 14, 2000
    4,823
    Altair-4
    +140
  5. cjn
    cjn
    Nov 5, 2005
    13
    3
    I tried the OmniRemote program (pacificneotek.com) on my T a couple of years ago. It did work but the IR transmission was too weak and directional to be of much use. If I'm going to have to sit that close to the target device I may just as well push the buttons myself! Also, the T screen's a bit too small to handle sufficient buttons.
    I really wouldn't waste the time - just get a decent programmable remote.
