Help: cables for: Digibox, DVD, VHS, TV, Amp
Discussion in 'Cables & Switches' started by chrishiggs, Sep 21, 2004.
  1. chrishiggs
    chrishiggs
    :lease: Firstly sorry if this has been gone over before. (Couldn't find posts with simelar components.)
    I am looking for advice on how to connect the following components:
    TV: Sanyo- 1 Scart (oldish, sorry not sure of model!)
    VCR: SEG VCR 306- 2 Scarts
    DVD Player: Toshiba SD330E- 1 Scart
    Digibox: Humax F2-FOX T- 2 Scarts, SVID/RGB Output (via SCART)
    Amp: Marantz PM55se- used for stereo out only-no surround sound capability.
    Any advice on the connecting of these bits and bobs would be most appreciated. A couple of specific questions are:
    The VCR, DVD, and Digibox all have phono stereo outputs that I can connect to my amp. Which should I use and will I still get stereo out from all the components?
    How does a particular method of connecting the components affect the tuning/channel alocation?
    Many thanks in advance! :thumbsup:
    Chris
