Quantcast
Help Buying Headphones. £25 budget. Best Quality for a set with 3.5m cable.
Allendk
I would recommend the Sennheiser HD201. Their cable length matches your requirement and you would have change leftover from your budget as well. They are outstanding value for money. Check their reviews on the web. I have been delighted with mine.
