Help Buying a plasma
Discussion in 'Plasma TVs Forum' started by paulbay, May 16, 2005.
  1. paulbay
    paulbay
    Whats the best plasma available at the moment? i'm looking for something between 2k - 3.5k 48" & High-Definition, preferably a panasonic.
    Also i'm getting the xbox 360 when it comes out, are consoles safe to use on plasmas, do i need extra stuff?
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    either TH42PV500, TH-50PV500 or wait for the PHD8 42/50
  3. Jazz Monkey Jr
    Jazz Monkey Jr
    Jan 10, 2005
    14,242
    2
    4
    137
    Garstang, Lancs
    +1,625
    either TH42PV500, TH-50PV500 (June) or wait for the PHD8 42/50 (Sept/Oct)
    The PV500 has everything built in, tuner, speakers, inputs etc.
    The PHD's will be panels, no tuner, inputs etc but are considered to be more tweakable, you just buy the boards you need.
    The PV500 will have HDMI which should be on the new xbox's, so should be a good choice for future proofing. I will be using my xbox with it, it should cause no problems.
  4. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    is there an echo in here?
  5. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    in here?
  6. Jazz Monkey Jr
    Jazz Monkey Jr
    Jan 10, 2005
    14,242
    2
    4
    137
    Garstang, Lancs
    +1,625
    Don't know, it is dark and I am scared.... :eek:
  7. Mr.G
    Mr.G
    Is there some more info about the PHD8 available?
  8. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    not alot at the moment but G8 glass same as PV500 Must have working HDMI 1.1 input the rest is largely unkown, price etc......
  9. minisisme
    minisisme
    May 17, 2005
    13
    Forgive me I’m a newbee. What’s the PHD8, is it a Panasonic or some sort of qualification?... Are the specifications the same for the37” PV500 which I am hoping to get?
  10. ukdan
    ukdan
    Feb 16, 2005
    1,135
    swindon
    +85
    Phd8 is panasonic. It is a panel only, does not come with a tuner or input boards.You will be able to fit the boards at an extra cost and in the configuration you want just like the pwd7. Hopefully released in september/october.
    hope that clears it up a little for you. :)
