Help Bush tv
Discussion in 'TVs' started by speedybee, Apr 11, 2005.
  1. speedybee
    speedybee
    Can anyone help with the following been given a Bush BTV 18SIL tv vcr combi with no remote tv is not tuned to any station, have brought One for all URC3420 but none of codes work, nor does manual search. Am i to throw tv in the bin or is there an easy solution to my problem :thumbsup:
  2. Tight Git
    Tight Git
    Mar 3, 2004
    6,332
    +597
    Hello Speedybee and welcome to the Forum. :)
    Can you supply more details, please?
    Did you see the set working before it was given to you?
    Was it tuned to another transmitter at its original location?
    Can you get any picture or sound at all (even noise)?
    Will it replay tapes?
    Does the one-for-all work with another set?
    The more info, the better! :smashin:
  3. JayCee
    JayCee
    Jan 20, 2004
    20,206
    Lanarkshire
    +1,931
    Using a universal or one-for-all type remote requires two codes....one for the Tv side and a different code for the Vcr.
    Do a manual search using the Tv codes.
  4. speedybee
    speedybee
    Thanks Tight Git for the welcome.
    I didn't see the tv working before but it will play back all video tapes.
    The one for all will work with my bush that is in my living room.Not that bothered whether the remote will operate the video just want to be able to tune tv stations, bush inform me that tv cannot be tuned without a remote, that is why i brought a one for all.I have tried the manual search the tv does not go into stand by mode. Unless i have done the search wrong but have followed instructions. :thumbsup:
  5. Tight Git
    Tight Git
    Mar 3, 2004
    6,332
    +597
    Speedybee,
    Does the one-for-all do anything? (volume, contrast, etc)
    We need to determine if it's the TV that's faulty, or the remote isn't "talking" to it.
  6. speedybee
    speedybee
    The remote will not do anything, had an email from one for all with a different code and this did nothing at all. :thumbsup:
  7. jon_mendel
    jon_mendel
    Jan 15, 2005
    852
    +9
    Sounds like it might be a duff remote. If it's any help, however, I've got an old Bush portable and you're welcome to borrow the remote on that to see if it helps (I would want it back though!) TBH, not sure if a remote for one Bush TV is likely to work for another....maybe someone else on the forum knows?
    Jon
  8. Tight Git
    Tight Git
    Mar 3, 2004
    6,332
    +597
    Codes do change from time to time, so two Bush TV's of different ages may well need different codes.
    That's why there are often several codes for each manufacturer provided by universal remotes. :lesson:
  9. jon_mendel
    jon_mendel
    Jan 15, 2005
    852
    +9
    Fair enough - thanks for the info.
    Jon
