help - broken Toshiba - colours reversed?
Discussion in 'Plasma TVs' started by chris99uk, Sep 10, 2005.
  1. chris99uk
    chris99uk
    hi, my Toshiba 42WP27 (20 months old) has gone a bit haywire - the colours have changed - greens are now blue, blue greens etc. making it unwatchable.
    has anyone experienced this?
    have had a repair company out but they said nothing can be done as it is an early model of plasma and I should buy a new one (from them)!!!
    thanks in advance.
    chris.
  2. fraggle
    fraggle
    Dec 11, 2002
    1,441
    Milton Keynes
    +29
    Can't you feed it an RGB signal and switch the green and blue wires? :)
  3. stevelup
    stevelup
    Aug 13, 2002
    6,132
    Swindon
    +843
    Your panel is actually a rebadged Panasonic 6 series.
    Have a look at this link and see if you can get a second opinion.
    What input boards do you have in the panel. Have you tried connecting up your sources using different connections / cables?
    Regards,
    Steve
