Help - Broken Speaker Terminal on Pio AX5i
K
kevtotty
In the process of moving house and tonights task was to pack up my AV gear.
To my dismay, I have managed to snap of the front right speaker terminal from the rear of my amp:eek:
I'm hoping it is replaceable as a seperate item.
Anyone any ideas on how much this may cost via a dealer? or is it something I could attempt myself??:lease:
Any thoughts???
K
K
kevtotty
Thanks for the response Jon
Out of interest what amp have you got?
How is it connected inside the amp?
Kev
jon smith
The AX5ai. It's easy to get inside the case, but some of the speaker terminals are easier to reach than others (the one I broke is probably the hardest to get to).
The threads are simply held by a nut on the other side (very simple replacement job if you can get to them easily).
K
kevtotty
Ta Jon
Is there a cable inside that case or does the connector sit on a circuit board???
Kev
Similar threads
