Help - Best leads for a new Tosh 36ZP38B
Discussion in 'General TV Discussions Forum' started by Richard Morris, Sep 15, 2003.
  1. Richard Morris
    Richard Morris
    I've just bought a new TV from John Lewis (I went to Cheadle, Cheshire), as they now have the Tosh 36ZP38B on special offer at £1450, with a free Toshiba SD330E DVD & Toshiba V753 VCR. Cost of course includes free delivery & 5 yr guarantee. I should get the package in about a month.
    Could anyone could tell me what would be the most suitable leads (scart etc) to purchase to get the best of out the set I would be really grateful. I've heard the ones they supply with the set are pretty basic. NB I also have the Grundig Freeview set so would need the best connetions for that. No matter what, it's still going to look a whole lot better than my current 9 year old Panasonic !!
  2. bazzae123
    bazzae123
    Mar 10, 2002
    315
    16
    I use the IXOS cables but just try any decent make. If you can ask if you can take them back if your not satisfied then you can start at the £50 level and see if you can spot the difference from the ones you already have.
    Bazza
  3. Richard Morris
    Richard Morris
    Thanks - will do
  4. cloudchaser
    cloudchaser
    May 17, 2003
    85
    London
    +8
    A month? You could try Toshiba directly and see if they can deliver faster for you. Get the order number from John Lewis and quote that to Toshiba.
    I was given a similar delivery date by my online retailer but when I called up Toshiba directly they delivered it within a week ;)
    hope that helps
    cheers
    *edit * Toshiba number - 0800 20 16 58
  5. hannanp
    hannanp
    Can you let me know how you got the price of £1450 at JL. I spoke to them this morning and was told £1950.
    Paul
  6. Richard Morris
    Richard Morris
    Paul,
    As mentioned - went to Heald green JL (nr Manchester) last Sunday. Item was on display at the price so went for it.
    It is a Toshiba limited offer so they may have used up their allocation ? Either way I'm sure Toshiba will continue this somewhere else.
    Good luck
    Cloudchaser - thanks for the number - will give this a try.
