Help!!! Banging From Gale 3080 Sub
Discussion in 'AV Receivers & Amplifiers' started by pugheaven, Apr 3, 2005.
  1. pugheaven
    pugheaven
    Jun 12, 2004
    581
    Elton
    +29
    Sorry for reposting (already in SUB section), however, could be one or the other!
    Currently using this sub and have been for about 2 years with a Yamaha 430 Amp. However, after disconnecting the sub for a few days, and now, reconnecting, everytime I switch input on the amp, I get a loud thud from the Sub. Any ideas as it's doing my head in? :lease: :lease:
  2. Harry T2
    Harry T2
    Jul 29, 2004
    482
    +10
    Can I ask why it was disconnected for a few days?
    Only asking, as we need to determine what has changed in your system pre and post "thud".
  3. wookie
    wookie
    If you re connected your sub when the Yamaha was turned on, You have blown the Yamaha's Muting Transistors.
  4. AV Monkey
    AV Monkey
    Oct 29, 2006
    811
    28
    hampshire
    +32
    /BUMP
    Did you manage to get this problem fixed if so can u tell me how much it was/ where u got it fixed i have exactly the same problem
