Help- Awful Line Speeds
cR4cKF0x 5TevE
Whilst I wait for BT Infinity I'm 'enjoying' the following router stats
ADSL Line Status
Connection Information
Line state: Connected
Connection time: 1 days, 22:55:31
Downstream: 1.688 Mbps
Upstream: 448 Kbps
ADSL Settings
VPI/VCI: 0/38
Type: PPPoA
Modulation: G.992.1 Annex A
Latency type: Interleaved
Noise margin (Down/Up): 6.0 dB / 14.0 dB
Line attenuation (Down/Up): 63.0 dB / 31.5 dB
Output power (Down/Up): 17.4 dBm / 11.9 dBm
FEC Events (Down/Up): 24910222 / 3000
CRC Events (Down/Up): 3050444 / 2994
Loss of Framing (Local/Remote): 0 / 0
Loss of Signal (Local/Remote): 0 / 0
Loss of Power (Local/Remote): 0 / 0
HEC Events (Down/Up): 1674726 / 1698
Error Seconds (Local/Remote): 382586 / 9725
and as a result my download speed (tested through various testers) is around 0.5Mbps.
Any idea why this is so awful? The line was activated on Tuesday 4th May, and has recently switched from fast path to interleaving.
beerhunter
First of all BT will not entertain questions about Line Speed until the Ten Day Stabilisation Period is over.
However in the meantime, try the BT Home Hub in the Test Socket of the Master Socket, and look at the router stats again. If you see an instant increase in Downstream speed, you have an Internal Wiring problem which is your responsibility - not BT's.
Even so you would need to wait for three days for the BT kit to catch up with tht Line Speed increase and thus speed up the actual performance.
BTW, I'm clutching at straws here. You may just be on along line and that is the kind of speed that you can expect.
cR4cKF0x 5TevE
Around 3.5km; I've always had line speed problems but put it down to the incompetence of my previous ISP (AOL) as well as the distance from the exchange.
