HELP !!!!!!!!!! av sales plasma wall bracket not universal as should be
Discussion in 'Home Cinema Buying & Building' started by foxyuk13, Oct 17, 2004.
  1. foxyuk13
    foxyuk13
    Sep 23, 2004
    207
    +9
    bought a universal wallbracket with tilt for my samsung 42 inch plasma ...... my adv is this is NOT UNIVERSAL FOR THIS TV...
    had to hacksaw the bracket that fits on tv itself as the bracket covers the power supply bit............. THIS IS DONE NOW
    mounted on wall NEXT PROBLEM AT TILT OR NON TILT........ THE POWER SUPPLY IS RESTING AGAINST THE FRAME ON THE WALL SO ITS TAKING THE FULL WEIGHT OF THE PLASMA...
    i have 2 choices cut another bit of the bracket so its free or IS THERE ANYWHERE I CAN BUT A POWER SUPPLY THAT ISNT AS THICK AT THE POWER IN BIT FOR BACK OF PLASMA??????????????
    HELP
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,294
    +1,217
    can you post a pic of the problem.....
  3. John Shaw
    John Shaw
    The brackets that RS100 do should solve your problem,they offer different mounting depth bars depending on where your connections are.They also have a tilt version...www.rs100.co.uk
  4. foxyuk13
    foxyuk13
    Sep 23, 2004
    207
    +9
    what i need is an angled power cord ...so it doesnt lean against the bracket...........
    can i buy this???????
    horneydragon i will ost u a pick when i can get helper to lift screen with me
  5. foxyuk13
    foxyuk13
    Sep 23, 2004
    207
    +9
    just to let u all know that i recd email this morning from ALISTAIR AT AV SALES ,,,,, who is going to locate me a right angle power adapter and is going to refund me some of the cost of the wall bracket............
    THIS IS WHAT I CALL CUSTOMER SERVICE
    :clap:
  6. MrPudding
    MrPudding
    Is it me Foxy or are you having no luck at all with your Plasma and accessories. Are you cursed??
  7. foxyuk13
    foxyuk13
    Sep 23, 2004
    207
    +9
    Your Telling Me.....
