Help ATI 8500DV
Discussion in 'Desktop & Laptop Computers Forum' started by oaklandraiders, Jan 6, 2004.
  1. oaklandraiders
    oaklandraiders
    Aug 2, 2002
    1,040
    41
    Surrey
    +14
    Yo
    This used to work in previous mb, but not in new one.
    Monitor just goes into standby, I've tried changing a few things in bios, AGP size to 256, but nothing works.
    Emailed ATI weeks ago, no help.
    John
  2. Chris Muriel
    Chris Muriel
    Jun 14, 2002
    7,100
    Manchester
    +712
    You might get some useful answers/ideas if you tell us more about your system (and possibly a weblink to a site that describes the card).
    The new mobo: Make/model ?
    AGP4 slot , AGP8 or what ?
    CPU ?
    Memory ?
    What PCI cards are installed ?
    Other pertinent details, including your PC's power supply ; it's not unknown for systems to fail when the PSU isn't man enough for the job (so what is Max (not the marketeers' "peak" rating) Amps for +3.3Volts, +5V, +12 V (should be written on a label on the power supply) ?
    Do you get any "beep codes" whilst it tries to boot ?
    Blank screen all the time - or do you get some initial text (like BIOS version) on the screen first ?
    Do the fans on the mobo come on ok ?
    etc. etc.
    Chris Muriel
  3. oaklandraiders
    oaklandraiders
    Aug 2, 2002
    1,040
    41
    Surrey
    +14
    Yo
    Its a K7VTA3 mb with 512 ram, 4xagp, amd 1800+, network and sound card, 350 W power, 40a, 20a, 15a, 0.8a, 0.5a, 3a for +5v to +5Vsb.
    It beebs twice on start up, nothing appears on screen
    Hope you can help.
    John
  4. Chris Muriel
    Chris Muriel
    Jun 14, 2002
    7,100
    Manchester
    +712
    The PSU specs sound good enough to me.
    (although I am no expert on AMD requirements , always used Intel CPUs).
    I believe 2 beeps will indicate a memory problem.
    Check the memory is correctly -seated for starters.
    You could remove 1 stick and if that doesn't help try the other one (unless you have other spare memory to try).
    There should be a "beep code" list in your mobo manual.
    Have you a different graphics card that you can try just to see if everything else is working ?
    Even an old PCI VGA card should work (assuming it defaults to PCI when nothing is inserted into the AGP slot - the manual should confirm this).
    You could also set another PC (with AGP slot) to bog-standard VGA and put your 8500DV in it to confirm that it still works.
    Report back afterwards & maybe someone with AMD mobo experience will have more suggestions.
    Chris Muriel
  5. oaklandraiders
    oaklandraiders
    Aug 2, 2002
    1,040
    41
    Surrey
    +14
    Yo
    Memory is fine, if I put in a PCI vga card it works fine. I'll check the number of beeps again though.
    Mobo manual doesnt help, nothing on their www about ATI either.
    ATI www helpfully says their cards dont work in some mobos ! Of course they dont give any more details.
    Card works fine in old mobo.
    John
  6. TooManyHobbies
    TooManyHobbies
    Nov 7, 2002
    1,304
    41
    South Yorkshire
    +13
    Evening just checked a couple of sites and from what I can sse you have a Phoenix Bios and 2 bleeps would definatly indicate a memory error.
  7. TooManyHobbies
    TooManyHobbies
    Nov 7, 2002
    1,304
    41
    South Yorkshire
    +13
    Edit.
    there 8 revisions of this board and 3 different types of bios fitted the most common being Award and only ECS can tell you what the beep codes means.
    But basicly it's a ram or video failure all other post errors should be displayed on screen with this motherboard.
    Do you know what revision the board is?
  8. TooManyHobbies
    TooManyHobbies
    Nov 7, 2002
    1,304
    41
    South Yorkshire
    +13
  9. oaklandraiders
    oaklandraiders
    Aug 2, 2002
    1,040
    41
    Surrey
    +14
    Yo
    Its revision5, just going to reboot and try a few bios changes.
    John
  10. oaklandraiders
    oaklandraiders
    Aug 2, 2002
    1,040
    41
    Surrey
    +14
    Yo
    No joy, its more of one very long beep with a hiccup in middle and monitor goes to standby.
    John
  11. TooManyHobbies
    TooManyHobbies
    Nov 7, 2002
    1,304
    41
    South Yorkshire
    +13
    I'd would change the motherboard and keep the 8500 as the issues seem to point to the motherboard.
    Had the 8500 myself and it was an excellent card.
  12. oaklandraiders
    oaklandraiders
    Aug 2, 2002
    1,040
    41
    Surrey
    +14
    Yo
    Its a new mobo and how do I know it'll work with replacement !
    john
  13. Chris Muriel
    Chris Muriel
    Jun 14, 2002
    7,100
    Manchester
    +712
    Probably a coincidence but on the MSI website/forum there was reference to a BIOS change where a new revision was noted as
    "system cannot boot when installing ATI8500DV AGP card and any PCI card"
    Not your mobo (or even same manufacturer) but worth checking for similar issues with your mobo-maker.
    (I have an MSI 845Emax2BLR mobo so I monitor the MSI site & forums).
    Chris Muriel
