help! arcam dv88+ & sim2
Discussion in 'Projectors, Screens & Video Processors' started by camlogan, Jan 23, 2003.
Tags:
  1. camlogan
    camlogan
    hi there all, I have an arcam dv88+ and a sim2 dmf projector.
    I can't seem to get it working with progressive though.
    I put the componet to 32hz on my r12 box (instead of 16hz?) and select progressive on the setup menu but it only outputs it in green? Interlaced looks great so i know it kinda works.
    does anyone have this combo and could offer me some advice?
    thanks
    CaM
  2. camlogan
    camlogan
    ok then - the solution was just to select the right mode on the remote for the interface box.
    thanks
    CaM
