Help!! Arcam AVP700-Only Direct Sources are working
Naass
Dear Friends,
I have been struggling with my AVP700 for few days now, trying to solve this problem:
The AVP700 freezes each time I try to switch to any other source other than CD Direct and DVD-A Direct.
When I push on DVD button for example, the AVP displays:
-Dolby Prologic II
-PCM
-Digital
No sound or image are produced and I cannot switch back to the CD Direct I was listening before.
I tried everything, changing the DVD player, cables, etc..
I also tried to connect the DVD player with a Coax and even with the Red/White analogue cables, the result was always the same.
The status of the AVP makes me think that the DAC side of it is out of order.
I tried to set it back to its factory default settings in the menu which is called by holding the RDS INFO + PRESET/TUME, for no result.
Does anybody have any idea or solution?
Thanks to all in advance for your precious help.
Does anybo
Naass
By the way, I read some threads about the importance of having the firmware up to date. I have no idea where to check the firmware version. I would appreciate if somebody could explain where to check it.
Thanks in advance.
Naass
Panasonic HZ2000 4K OLED TV Review | The best OLED for movie viewing in 2020
