Help appreciated: what is this input?
Discussion in 'LCD & LED LCD TVs Forum' started by Bert Coules, Mar 1, 2013.
Tags:
  1. Bert Coules
    Bert Coules
    Mar 17, 2002
    3,406
    +181
    I have a Relisys LCD TV, model LV87E, but not the user guide. There's a mini-jack (I think) connector on the back which I can't identify:
    [​IMG]
    Not the 12V DC input but the other one. The symbol suggests that it's another input, but what could it be for? There are already phono inputs for AV1 and 2, which cover audio, component, and composite video.
    Any thoughts will be appreciated. Many thanks.
    Bert
  2. SirTiger007
    SirTiger007
    Apr 7, 2007
    778
    46
    +204
    It looks like a 3.5mm input, so if you took the sound from a headphone socket from somewhere, you can plug it into this and get stereo sound using a 3.5mm to 3.5mm cable. Or even optical out to 3.5mm to keep digital fidelity. Maybe!
  3. Bert Coules
    Bert Coules
    Mar 17, 2002
    3,406
    +181
    Thanks for that. Yes, it makes sense: more sense than my initial idea which was that it might be a microphone input.
    What I should do is connect up the set (it's been unused and in storage for some years) and run though the i/o menus to see if there are any clues there.
    Bert
  4. ChrisPB
    ChrisPB
    Jun 9, 2007
    398
    +35
    Could it be a PC audio input ?
  5. Curly99
    Curly99
    Dec 29, 2006
    9,426
    +2,255
    thread moved
    Curly
