Help!!! Anyone with Kef HTS2001's? I've broken the stand attachment screw!!!
Discussion in 'Home Cinema Speakers' started by Blenky, Feb 7, 2003.
  1. Blenky
    Blenky
    Jul 27, 2000
    420
    46
    Hove, England
    +110
    For anyone who owns Kef HTS2001 satellite speaker I need advice please
    I wanted to move one of the speakers attached wall mounting so it would operate as a stand. I got the stand off using an Alan key but when I re attached it and tightened the screw the stand still wobbled :(
    Unfortunately after trying to tighten it more the head came off the attaching screw:eek:
    I am now left with a headless screw jutting out of the speaker. I can't remove it as the slot it goes into is too narrow to insert pliers!
    Anyone got any idea how
    a) I can remove the headless screw without leaving any of it behind?
    b) get a replacement screw so I can re-attach the stand?
    Any advice would be gratefully received
    Steve
  2. Jase
    Jase
    Mar 16, 2001
    9,535
    UK
    +933
    Send an email to Kef and see what they suggest. www.kef.com is their website.
  3. wookie
    wookie
    You could try a stud extractor.
    Drill a suitably sized hole into screw.
    Wind screw extractor into drilled hole in screw anticlockwise, it should then "bite" and unwind the screw. :clap:
  4. Blenky
    Blenky
    Jul 27, 2000
    420
    46
    Hove, England
    +110
    Wookie and Jase - thanks a lot for your suggestions - I will pursue both!
